Can someone please confirm this will work..
Old Oct 29, 2006 | 11:33 AM
LenT1's Avatar
I will be ordering this part within a few days and I just wanted to be sure it would work for what I need. It says it is for a corvette 93-96 LT-Based engine only so please help me out here..
Summit part # ASP-945803
I have an internally balanced engine.
Thanks.
Old Oct 29, 2006 | 07:06 PM
LenT1's Avatar
TT ^
Thanks in advance.
Old Oct 29, 2006 | 07:55 PM
zx1216's Avatar
hmm, i don't really see a reason why it wouldn't work, it says it comes with a water pump pully which is non existant on a lt1 tho... I do think there are better parts to buy for $150
Old Oct 30, 2006 | 11:23 AM
When I posted that link on the Summit website, I got an integrated crank damper/pulley and an alternator pulley, noo water pump pulley.
Check the required projection of the pulley. The Corvette hubs are different, but that might not affect the pulley. But I know ASP makes a set for the F-Body LT1, because I ran one for several years.
Old Oct 30, 2006 | 07:29 PM
LenT1's Avatar
OK I think I found it... Don't know why it did not come up at first.
ASP-945100
It should do the trick?
Old Oct 30, 2006 | 08:27 PM
anaik's Avatar
What kind of trans do you have. ASP says you should idle at 800 rpm with the 945100 damper/pulley to maintain a proper charge at idle. A stock A4 idles at 550 in gear, an M6 at 800.
Old Oct 31, 2006 | 03:47 AM
LenT1's Avatar
I have a th400 with a 3300 Vig.
DirtyDaveW
Dec 1, 2016 05:37 PM
RX Speed Works
Oct 1, 2015 10:19 PM
dkred94z
Aug 20, 2015 03:09 PM
NewsBot
Apr 9, 2015 07:10 AM
mobleman
Mar 15, 2003 08:44 AM
