can someone host my dyno graph
Old Feb 22, 2006 | 02:20 PM
94 guy's Avatar
please look at the dyno graph and tell me why it's jumps.
this a full bolton car. the heads i ported myself, gm846 cam,11.70comp,comp r's,futral motorsports tune. can someone tell me why the car falls off so low and why does it jump around (not steady).
Old Feb 22, 2006 | 02:47 PM
cas0484's Avatar
Re: can someone host my dyno graph
Sign up for a free webshots account. www.webshots.com That's where I put my dynograph. If you cant get it figured out shoot me an pm and i'll put i tup for ya.
Old Feb 22, 2006 | 02:49 PM
91RSLT1's Avatar
Until then give us the "report card", that is #'s and mods. Don't keep us waiting.
Old Feb 22, 2006 | 02:50 PM
JakeRobb's Avatar
Super Moderator
I'll host it. Email in profile.
Old Feb 22, 2006 | 03:07 PM
94 guy's Avatar
jake i sent you the graph
Old Feb 22, 2006 | 04:14 PM
JakeRobb's Avatar
Super Moderator
Click on this one to see the full size image.
Old Feb 22, 2006 | 04:46 PM
91RSLT1's Avatar
Very Nice. But what are your mods?
Old Feb 22, 2006 | 05:20 PM
97bowtie's Avatar
Re: please look at the dyno graph and tell me why it's jumps.
I'm going to guess that this is the reason:
Overall, not terrible numbers for home ported heads. Unless you really know what you're doing, you aren't going to see the 400-430 rwhp the LE/AI h/c packages are seeing.
By reading your post, it appears this is a stock shortblock (you said it's a full bolt-on car + heads/cam, so I assume it's not a 355/383). If so, how did you get 11.7:1 compression?
Old Feb 22, 2006 | 05:58 PM
94 guy's Avatar
this is a new 355 with 600 miles.
Old Feb 22, 2006 | 09:45 PM
TQdrivenws6's Avatar
What is the lash set to? Comp R's need to be set at zero, or 1/16th max. There is alot of power in valve adjustment with Comp Rs.
Old Feb 23, 2006 | 03:43 AM
30696bird's Avatar
It's a GM846..........I thought that was pretty good (peak RWHP) . What were you expecting?
Old Feb 23, 2006 | 05:43 AM
Zeueses 97 RamAir's Avatar
Thats good for home ported heads gm847cam you would have seen 15 more horses. just get some more tuning in and try to get as mucha s you can out of them...
Old Feb 23, 2006 | 08:33 AM
94 guy's Avatar
this is an A4 car. i'm happy with the #'s i just don't see why the line is jumping. also the valves are set at 1/16th of a turn. futral motorsports thinks the lifters are causing this low rpm. said he seen them do this before.
Old Feb 23, 2006 | 12:00 PM
atljar's Avatar
What are your knock counts/retard doing?
Old Feb 23, 2006 | 01:28 PM
94 guy's Avatar
i have the knock setup to only work or pull timing under 4000rpm anything above that it's locked out so it will not pull anything.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
