Can an Opti becaome "over heated"?
Old Mar 9, 2004 | 04:22 PM
stang_killa94's Avatar
I was wondering if an opti can over heat or get too hot to work properly? Everytime my car gets past the half way mark on the temp gauge my car starts acting really weird almost like when i burnt out my plug wires. And it cant be the wires becasue i swapped them out along with the LT install. Or how about the wires themselves? Can they get too hot to work right?
Old Mar 9, 2004 | 05:08 PM
Fux0redImages's Avatar
My car used to do the same thing. Changed the coil and got a 160 thermostat, now the problem is gone. Now, I have my PCM reprogrammed to have the fans come on sooner, so I don't see temps much above 160. The problem hasn't come back in months.
Old Mar 9, 2004 | 05:09 PM
xxsaint69x's Avatar
You problem is not the opti. Its one of your sensors that pcm reads when it enters the CLOSED loop. The temp has to be up there to go into closed loop (running off sensors) vs open loop (runing off the pcm program). So when your car is cold it runs in the open loop, but once it warms up to the temp ( i think 150) it enters closed loop. Make sense?
I would make sure all your sensors work
Heat can cause odd problems with the opti and also the ICM.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
