Can the LT4 intake accept a 58mm throttle body?
Old Mar 12, 2004 | 10:17 PM
Cerwin Vega Fan's Avatar
Question Can the LT4 intake accept a 58mm throttle body?
http://store.summitracing.com/partde...NAL%2D12550630
Does this intake come ported for a 58mm throttle body or does it have to be ported?
Old Mar 12, 2004 | 10:22 PM
rskrause's Avatar
Moderator
It will need to be "ported". But it's quick work as it doesn't have to be too precise and the aluminum is soft.
Rich Krause
Old Mar 13, 2004 | 07:31 PM
arnie's Avatar
When porting, the idea, is to be able to bolt up TB without any mismatch (bigger into smaller) to disrupt airflow. This is something the people that endorse bolting a 52 mm TB to a 52 mm opening, do not seem to understand. Mismatch waiting to happen!
Old Mar 13, 2004 | 07:33 PM
So 52 is the biggest you should go?
Old Mar 13, 2004 | 07:39 PM
arnie's Avatar
Geez, you're quick! Guess I gotta take credit for confusing you.
Not sure what I stated to do so, however, what I was implying, was to make sure the opening you generate at the TB mounting surface of the intake, is not smaller, AT ANY POINT, than the TB you are bolting up to the manifold. IOW, at any point, or at any degree, around the hole, once the TB is bolted up.
What I am alluding to, is to allow for any mounting bolt hole slop.
Old Mar 13, 2004 | 07:42 PM
Make sure the holes are the same size would have been easier to say.
Old Mar 13, 2004 | 07:47 PM
arnie's Avatar
No, I'm trying to say, make sure the diameter of the holes, in the manifold, are, bigger, by the amount of the mounting bolt hole clearance.
HectorM52
Jul 30, 2017 11:46 AM
birdblack
Dec 30, 2014 06:59 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
BM93Z
Aug 22, 2002 02:45 PM
