Can the LT4 intake accept a 58mm throttle body?
http://store.summitracing.com/partde...NAL%2D12550630
Does this intake come ported for a 58mm throttle body or does it have to be ported?
When porting, the idea, is to be able to bolt up TB without any mismatch (bigger into smaller) to disrupt airflow. This is something the people that endorse bolting a 52 mm TB to a 52 mm opening, do not seem to understand. Mismatch waiting to happen!
Originally posted by Cerwin Vega Fan
So 52 is the biggest you should go?
Not sure what I stated to do so, however, what I was implying, was to make sure the opening you generate at the TB mounting surface of the intake, is not smaller, AT ANY POINT, than the TB you are bolting up to the manifold. IOW, at any point, or at any degree, around the hole, once the TB is bolted up.
What I am alluding to, is to allow for any mounting bolt hole slop.
Originally posted by arnie
Geez, you're quick! Guess I gotta take credit for confusing you.
Make sure the holes are the same size would have been easier to say.
Jul 4, 2005 05:00 PM
BM93Z
Aug 22, 2002 02:45 PM
