Can a loose MAF connection cause a no start
Old Jul 7, 2004 | 09:36 PM
wicked_95z's Avatar
Just finished new dist. install and car wont start. Got 40psi fuel and spark down to the plugs. Just before the dist. install when the car as running and i pushed the maf connector to the side the car would die. I was under the impression that if the MAF failed the computer went into Speed density and used the MAP sensor. Just wanted to check on this before I tear everything back apart to check the timing of the dist.(I know in my heart thats what happened ) Thanks
Old Jul 7, 2004 | 09:48 PM
TobyZ28's Avatar
When your car is running and you disconnect the maf the car will die. If you start the car with the maf disconnected the car will run off the tables.
Old Jul 7, 2004 | 10:12 PM
97Z-M6's Avatar
my car wont die it will revert over to speed density.
Old Jul 7, 2004 | 10:34 PM
TobyZ28's Avatar
We both have OBD1 computers (95's) I'm not sure about OBDII's like yours, its likey they could differ.
Old Jul 7, 2004 | 10:46 PM
97Z-M6's Avatar
nope i have a obd1. i converted
if you look in the programming of the pcm you can in a sence turn off the maf and just run speed density. instead of unplugging the maf and gettign a code.
Old Jul 8, 2004 | 11:33 AM
wicked_95z's Avatar
Well I unplugged the MAF and still got nothing so I guess I'm tearing it down again and check the placement of the dist on the cam
DirtyDaveW
Dec 1, 2016 05:37 PM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
pete53
Dec 9, 2014 07:31 AM
Jul 4, 2005 05:00 PM
