Can a loose MAF connection cause a no start
Just finished new dist. install and car wont start. Got 40psi fuel and spark down to the plugs. Just before the dist. install when the car as running and i pushed the maf connector to the side the car would die. I was under the impression that if the MAF failed the computer went into Speed density and used the MAP sensor. Just wanted to check on this before I tear everything back apart to check the timing of the dist.(I know in my heart thats what happened
) Thanks
) Thanks
Originally posted by toby360
When your car is running and you disconnect the maf the car will die. If you start the car with the maf disconnected the car will run off the tables.
Jul 4, 2005 05:00 PM
