Can I use butt connectors on the wires to the temp sensor and be ok?
Today I was under my camaro pulling the starter and I noticed of of the wires goin to the temp sending unit (I assume that's what it is, goes into the water pump or just below it?) had a section with exposed wire. I cut out the inch of bad wire and I was going to reconnect it with butt connectors but my dad says that might throw off the signal since sensors read in ohms, and that I should ask first. Is it ok or is there some other way to repair it that I should do instead?
Re: Can I use butt connectors on the wires to the temp sensor and be ok?
dont know if it is proper, but i have used butt connectors on the wires to that sensor before. the PCM temp readings were exactly the same to the degree as they always were before i did it (i always scan/logged when i drove that car)
its only like 15-20 dollars at a dealer.......if you got the money I would replace it, if not...then try it and if it doesnt work out, then at least you know it doesnt cost much to replace.
If you use a good connector and crimp it properly, you should be ok. My personal preference is to slide a little heat shrink tubing over one end of the wire, then solder the wires together. Then slide the heat shrink tubing over the splice and shrink it down.
