Can I use butt connectors on the wires to the temp sensor and be ok?
Old Apr 19, 2005 | 10:03 PM
joey93turbo's Avatar
Today I was under my camaro pulling the starter and I noticed of of the wires goin to the temp sending unit (I assume that's what it is, goes into the water pump or just below it?) had a section with exposed wire. I cut out the inch of bad wire and I was going to reconnect it with butt connectors but my dad says that might throw off the signal since sensors read in ohms, and that I should ask first. Is it ok or is there some other way to repair it that I should do instead?
Old Apr 19, 2005 | 10:08 PM
chevyguy3's Avatar
Re: Can I use butt connectors on the wires to the temp sensor and be ok?
dont know if it is proper, but i have used butt connectors on the wires to that sensor before. the PCM temp readings were exactly the same to the degree as they always were before i did it (i always scan/logged when i drove that car)
Old Apr 19, 2005 | 10:54 PM
MarkyMark's Avatar
its only like 15-20 dollars at a dealer.......if you got the money I would replace it, if not...then try it and if it doesnt work out, then at least you know it doesnt cost much to replace.
Old Apr 19, 2005 | 11:39 PM
Well the thing is the lead goes into the harness. I didn't cut it at the sensor, but about half way between where the wires go into the harness and the sensor. Buying a new sensor wouldn't help me, I don't think.
Old Apr 19, 2005 | 11:44 PM
If you use a good connector and crimp it properly, you should be ok. My personal preference is to slide a little heat shrink tubing over one end of the wire, then solder the wires together. Then slide the heat shrink tubing over the splice and shrink it down.
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
