Can I run a comp 305 in my lt1 without tuning?
Old Jan 26, 2005 | 11:14 AM
80TA's Avatar
Can I install the comp 305 in my a4 with no tuning will the car idle or stall out all the time.I have a 2800 vig if that matters.I will eventually get some programming but not right now if dont' have to.I plan on sticking with obd2 not obd1.I prefer the extra detail on diagnostics that obd2 gives.
Old Jan 26, 2005 | 11:19 AM
tanker's Avatar
Re: Can I run a comp 305 in my lt1 without tuning?
100% yes my friend is running EX 224/230 with basically no tune, just a little raised idle speed and changed timing at idle, and it runs very smooth. We ran it with stock tune for no problems as well. It you get tunig cable ($40-$50),I will hook u up with software, and I will change idling for you
80TA's Avatar
Also is the right part number 7-305-8.And I thought this cam wasn't an extreme energy but think it is.Do I have to run type r lifters or are stock type fine.I hate the comp r personally.
Old Jan 26, 2005 | 11:25 AM
tanker's Avatar
If you stick with OBD-2, I won't be able to help you. Then contact Ion (madwolf), he knows what he's doing for a great price
Old Jan 26, 2005 | 12:01 PM
Fast Caddie's Avatar
I agree, Ion does great work. Mail-order tunes are relatively inexpensive, so i'd plan for that while you do the swap. Ion will do a PCM exchange deal with you so you can install the PCM with all the calibrations you want at the same time you swap the cams. Only takes 10-15 minutes to change PCMs.
Old Jan 26, 2005 | 07:50 PM
RansZ28's Avatar
My tune from pcmforless was great! Fast turn-a-round time
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
