can i remove the guide plates and just run self alligning rockers
Old Jun 10, 2004 | 07:04 PM
mehoffz24's Avatar
i bought afr heads and i wanted to reuse my basically new comp 1.6 rockers. there shouldnt be a problem as long as i find hardened washers to put in place of the plate? where do i find the washers and can i use these rr's without a problem.
Old Jun 10, 2004 | 07:07 PM
llafro's Avatar
It shouldn't be a problem to use self-aligning rockers and remove the guideplates. Just don't use SA rockers with guideplates.
Old Jun 10, 2004 | 08:51 PM
Dave89IROC's Avatar
I believe if you read the paperwork for those heads, they say that if you run SA rockers, remove the guideplates and use hardened headbolt washers there to keep the geometery right
Old Jun 10, 2004 | 09:34 PM
mehoffz24's Avatar
dave you are correct but when i talked to an engine builder he tried to get me the washers and couldnt, which i found weird. I tried to call AFR but couldnt get through. SO i wont run into a problem if i get washers and keep SA rockers?
THANKS
Old Jun 10, 2004 | 10:04 PM
I bet some ARP head bolt washers would work.
Old Jun 11, 2004 | 11:29 PM
DarinsTA's Avatar
make sure the retainers set low enough to clear the rails of the SA rockers! If they hit the retainer you could do some serious damage. IE drop a valve.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
alphaauto
Jan 23, 2015 07:42 AM
95chwagon
Jan 13, 2015 09:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
