Can I relocate my opti vent? Trick flow Purchased
I don't want to defile my ceramic coater trick flow elbow if I don't have to.Can I just leave it hang in a secure spot or put it east of the elbow? Is it a vaccum or does it just resonate cool air. Mike
I had the same problem/question. Then I saw what another member on the board had done.
Between the elbow & MAF ,take a AWL & poke a small hole in the rubber sleeve, spray some silcone on the hole, then push in that opti vent fitting. Problem solved ! Thanks to John
