Can i drive like this??
Old Apr 17, 2008 | 01:54 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
i got a 96 trans am lt1, with longtubes, ory pipe and deleted the air/egr, i know i am going to need a tune but whenever i get it all on it may be a couple of weekd before i can afford a tune, would it hurt to drive it without a tune or will it mess anything up?
Old Apr 17, 2008 | 01:56 PM
96' Formula WS6's Avatar
No you wont mess anything up with a tune. Drive as you please.
Old Apr 17, 2008 | 01:57 PM
northdakota93z28's Avatar
i think he meant without a tune.
drive it like you stole it!!
Old Apr 17, 2008 | 02:06 PM
ok then sounds sweet , cause "I'm all throttle , no bottle"
Old Apr 17, 2008 | 02:33 PM
JakeRobb's Avatar
Super Moderator
It'll be fine, but you'll get crappy gas mileage and you might see some black smoke in the exhaust. You might also smell gas in the exhaust.
Old Apr 17, 2008 | 02:40 PM
ill see black smoke in the exhaust before i tune it or after i tune it ? and how bad with the gas mileage be?
Old Apr 17, 2008 | 02:45 PM
white97T/A's Avatar
You don't need a tune for just putting LT's and exhaust on, the computer can compensate accordingly. You will need some minor programming done to keep your SES light turned off. Once the computer learns to compensate for the better flowing exhaust you will have improved gas mileage.
Old Apr 17, 2008 | 02:49 PM
2000GTP's Avatar
Agreed, I drove weeks before finally getting a tune done, had no issues. You might smell a noxious/gasoline smelling odor, that will be because of the lack of cats.
Old Apr 17, 2008 | 03:14 PM
oh ok sweet cause on another site and guy said this "your car will be down on power because the mods are too extensive to have the pcm self correct itself for proper fuel trim, etc." so i was like what is he talking about ?
Old Apr 17, 2008 | 04:33 PM
ss.slp.ls1's Avatar
Cam - yes, headers - no.
Old Apr 17, 2008 | 05:20 PM
oh ok , so should i even get a tune if i just have headers and ory pipe
Old Apr 17, 2008 | 05:33 PM
Its a good idea to get it tuned. Just "tuning" the PCM on a totally stock engine will net you 10-15HP. Once you start modding, you'll probably gain more than that with a good tune. The question you asked was can you drive it without a tune, or will it mess anything up. The answer is YES... you can drive it without a tune, and NO, it will not mess anything up, it will not pour black smoke out the exhaust.... you will be fine. But that does not mean that you will not see improved performance with a tune. You'll need a tune, or O2 sims, to turn the SES light off.
Old Apr 17, 2008 | 10:13 PM
ok well i have an ory pipe and waiting on my longtubes to get here, so i think i have 2 o2's on my car i believe? but do i just need to unplug those and get o2 sims until i get a tune or just leave them unplugged ? i will need a tune anyway cause i am going to delete the air/egr anyways
Old Apr 17, 2008 | 10:18 PM
Doh stupid typos. Thats what I meant to say
Old Apr 18, 2008 | 07:29 AM
Your 96 has 4 O2's - two O2 sensors in front of the cats - you can't delete those; two more after the cats. Those are the ones that tell the PCM there is no cat. They have to be replaced with O2 sims, or the code needs to be programmed out. Running temporarily without anything plugged in will set codes and turn the SES light on, but isn't going to affect engine operation.
