Can I do this?
Old May 1, 2004 | 05:31 PM
Greasepunk's Avatar
Can I do this?
I don't know if this is the right forum for this but I'll give it a shot...
I have a Suncoast Creations SS hood and it has a baffle a few inches into the scoop past the grill, can I remove the baffle safely without causing any damage. I don't think it would happen but could it cause a lean condition at high speeds? I know this is a dumb question but there has to be a reason for the baffle in the first place, I just don't know what that reason is, lol.
Old May 1, 2004 | 05:34 PM
simple's Avatar
the baffle is there to stop water from entering
but i've heard of alot of people removing it with out any ill effects
Old May 1, 2004 | 05:45 PM
Greasepunk's Avatar
That's weird then, the gap for air to pass through is about 1/2" and at the bottom so all the wind would push the water on the hood into the opening. So I guess it wouldn't matter if I removed it. Thanks.
Old May 1, 2004 | 05:50 PM
simple's Avatar
i've never done or seen it done personally. do a search on here to confirm tho!
