What did this motor come out of?
Old May 1, 2004 | 11:31 AM
Brandon94Z28's Avatar
I am looking to buy an LT1 motor. My friend has an LT1 laying around in his garage. It was a core motor and we don't know what it come out of.
The numbers on the block are v11287uc
The head castings are 10207643 The last number may be a 9 though.
If you guys could tell me what it come from that would be awesome.
Brandon
Old May 1, 2004 | 12:02 PM
The head casting is the same as what is on my 1995. The block number you gave V 11 28 7UC
V=Flint engine plant
11=November (month produced)
28=day of month produced
7UC=type code -I don't have a breakdown of that
Try looking the the VIN derivative by the oil filter and see what it says. It will at least tell you the year.
Old May 1, 2004 | 01:23 PM
Thanks Shoebox!!
Did the f-bodies and vettes have the same castings on the heads?
Old May 1, 2004 | 01:27 PM
Cmr0z28's Avatar
Originally posted by Brandon94Z28
Thanks Shoebox!!
I believe so.
Old May 1, 2004 | 03:13 PM
my94blackz's Avatar
Well go threw and start looking for clues. Easiest way to distinguish between vettes and f-bods is to pull the pan, 4bolt mains. Im assuming the engine is out of the car. If it is a 93 f-bod it has speed density no mass air, Easy way to tell between a 94-95 lt1 is the intake, 94's have a u shaped pcv and a different throttle body coolant route than 95's. If it is an lt4 pop the valve covers it should have roller rockers (i think). I hope that lil bit helped i dont kno much about the 96-97's.
Old May 1, 2004 | 05:27 PM
The motor was a core so it doesn't have the intake, throttle body, mas, or anything. Good idea about checking the mains. I had forgotten about that.
Brandon
Old May 1, 2004 | 05:30 PM
simple's Avatar
is 327 cast onto the block anywhere?
Old May 1, 2004 | 05:54 PM
Yes it has 327 cast into the block.
thanks
alex5366
Mar 27, 2015 03:30 PM
transam_388
Mar 15, 2015 11:53 AM
NewsBot
Dec 28, 2014 06:20 PM
