can a hotcam go into the 11's?
Re: can a hotcam go into the 11's?
Originally Posted by ze doktor
that article was from sport compact car and it was a stock sentra, and they had to cut the roof off of it and all of the body panels to get it to break 13's.
the post was never about the chassis, just the motor. is it possible? hell yeah. but when it comes to drag racing the chassis is important and should be assumed to be hand-in-hand with making power to get the car to go somewhere. many people don't realise that there are two sides to the coin or just don't want to put the effort into chassis work because big dyno numbers make superstars out of slow cars or maybe they just don't know.
Power isn't the one thing that produces good track times.
Either is suspension & tires if you can't drive
I know a guy with ET Streets on a BOLT ON ONLY 5.0 that was cutting 2.4 60's ...
Knowing your car and how to drive it well supercedes any mods. I mean come on, any pony car should be able to pull off at least a 1.8 or 1.9 with ET Streets. Some can do that on street tires.
Bottom line is a hot cam CAN go into 11's with some sticky tires, and a little suspension work. Full Bolt-ons is a must. And some reasonable weight reduction. I mean Im not saying it has to be gutted, but it could use some. And awesome heads.
Originally Posted by engineermike
Frank95Z has gone 11.40 at 116 mph with the Crane 210/224 cam, stock heads, stock bottom end, all motor.
Originally Posted by snakeatinZ
Regardless Frank did this with Hot cam and all motor.
NO, Frank did this with Crane's baby cam. This wasn't the HOT cam, it's even smaller.
Ben
