Can heads be pulled off with motor in?
Old Feb 11, 2006 | 08:24 AM
  #16
Jeff95TA's Avatar
Re: Can heads be pulled off with motor in?
Originally Posted by SLeeper94Z
Links are dead just thought you should know
Oops. Fixed.
http://home.comcast.net/~jsaccani/Je...al_Writeup.doc
http://home.comcast.net/~jsaccani/Je...l_Pictures.doc
Old Feb 11, 2006 | 09:24 AM
  #17
Kevin Blown 95 TA's Avatar
Originally Posted by FastZinTennessee
Forget trying to take the coolant crossover tube off with the heads in the car- get the heads completely unbolted from the exhaust, block and accessory bracket, then you get on one side with a buddy on the other and remove both cylinder heads at the same time. Then with the heads out of the car take the crossover tube off.
It can be taken off and re-installed with the heads in the car. No more of a PITA than any other job on these F-bodies.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Chris Anderson
Jan 27, 2015 08:30 AM
NewsBot
Dec 28, 2014 06:20 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
