Can a distributor be use on an Lt1?
Old Aug 30, 2004 | 10:19 PM
30thCamaroZ's Avatar
If going to a carb. style manifold and actually making the car carbeurated can you use a distributor on an LT1 or is the hole not there in the block? and if it's not there could I have it machined into the block?
Old Aug 30, 2004 | 10:24 PM
Kyle@CSS's Avatar
Re: Can a distributor be use on an Lt1?
The hole is there.
Old Aug 30, 2004 | 10:25 PM
JDBlaze85's Avatar
yes it can accept a standard distributor. I've done the carbed conversion before and it worked. pretty easy, makes the engine compartment alot more good looking.
Old Aug 30, 2004 | 10:32 PM
Terran2k's Avatar
Ive seen pictures of this before. it was on a board member's car. so i know it'll fit.
Old Aug 30, 2004 | 10:34 PM
texlurch's Avatar
Everything internally is the same. The LT1 uses a bolt in idler gear to turn the oil pump. Remove that and insert the dist.
Old Aug 30, 2004 | 10:41 PM
Thanks a lot. looks like that will be the route I'm going.
DirtyDaveW
Dec 1, 2016 05:37 PM
brentbrowning01
Dec 3, 2014 10:36 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
JoshWhite
Dec 15, 2001 04:21 PM
