Can anyone point out what relay this is?
Old Jun 26, 2006 | 06:44 PM
  #16
Dave89IROC's Avatar
Re: Can anyone point out what relay this is?
Originally Posted by JWBerk94Z
By the way, VATS is bypassed in my pcm so the fuel won't be cut. However, I just had it running with this wire bypassed to ground and all seems well. Can anyone foresee any problems with this?????
TIA
nope, its fine
Old Jun 27, 2006 | 05:10 AM
  #17
JWBerk94Z's Avatar
Hey, thanks for the reply. From what I understand from reading here, the wire I grounded on the relay is only grounded during starting. I have it grounded all of the time now. Still seems ok?
Sorry for the repeat, but I just want to be sure it is clear what I did. This seems like an easier solution to bypassing the VATS than the resistor in line under the column. Why don't more people bypass it this way? Have I missed something?
Old Jun 27, 2006 | 06:17 AM
  #18
Dave89IROC's Avatar
you'll be good, the relay doesn't get power till the key is turned to the crank position, and the neutral safety switch will still work too
Old Jun 27, 2006 | 08:41 AM
  #19
93Phoenix's Avatar
Wow this sounds exactly like my problem, fast96lt4 and JWBerk94Z, was your car starting, or even cranking? Mine won't even crank, but the security light does flash, only drivable if you push start it.
Damn VATS, causes more problems then it solves.
Old Jun 27, 2006 | 08:51 AM
  #20
fast96lt4's Avatar
My car was not even cranking, security light was flashing as well as my dash lights were all out. I changed a new ignition switch, dash lights came on but car would still not crank. Tested wires for shorts and came up with a bad TDR.
Old Jun 27, 2006 | 02:35 PM
  #21
JWBerk94Z's Avatar
My car wouldn't crank at all. From what I understand, if I hadn't had VATS disabled in my pcm it would have shut off fuel soon after it was push started. Now I have the small wire from the VATS (maybe supposed to call that box the BCM)to the TDR grounded all of the time and it looks like it runs fine.
OutlawPerforman
Oct 30, 2017 05:40 PM
Quickss96
Jan 29, 2016 05:56 PM
jerrysims71
Aug 15, 2015 12:47 PM
Boss002
Jul 9, 2015 03:33 PM
Jmj93z28
Jul 8, 2015 06:58 AM
