Can a 3rd gen rear fit a 4th gen?
Old Aug 6, 2003 | 02:13 PM
Screamin95's Avatar
Will a third gen rear fit and work in a fourth gen car? And if not why?
Old Aug 6, 2003 | 02:22 PM
sssalah's Avatar
All the mountings are the same, not so sure about the length but don't think it'd be way off. And there is no ABS.
Why would you want to change to this rearend? is it the 9 bolt borg warner?
Old Aug 6, 2003 | 02:38 PM
Screamin95's Avatar
no its a 9 in with 4.11 gear and i can get a good price on it. can the abs be made to work?
Old Aug 6, 2003 | 02:41 PM
While all the attachment points are the same, the 3rd Gen rear axle assembly is a full 3" narrower than the 4th Gen. You will probably have a problem with the disc brake caliper mounts.
Old Aug 6, 2003 | 02:47 PM
timelord's Avatar
I just put a 3rd gen 9" 4.11 on mine,it came with 3rd gen brakes and took a little adapting but went on pretty well.
You will need wheels with 4.5 backspacing instead of the 6" we have with the stock wheels.
I had spacers made to run my stock wheels on the street and use GTA wheels at the track without the spacers.
My 9" came with 3" studs which is what allows me to do this.
Old Aug 7, 2003 | 01:11 AM
1982z28with18s's Avatar
You can run it. You just need spacers. I've got a pair of 2 1/4" spacers and a pair of 1 1/4" spacers. Sorry I don't have pics, but they are just like these, only used. http://www.skulte.com/adapters.html
If your interested I'll sell either pair. I no longer need them. Let me know.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
JasonD
Jul 15, 2002 02:17 PM
