Cams?
Old Sep 12, 2004 | 12:38 AM
HardtopSS's Avatar
Cams?
I am looking in to buying a cam and rocker rollers for my M6 97. I wanted to know some nice Daily Driveable cams. Would I need rocker rollers for a new cam? How much gains would I be looking at with Headers and a cam and tune?
Old Sep 12, 2004 | 01:41 AM
HardtopSS's Avatar
Re: Cams?
Bump.
Old Sep 12, 2004 | 03:16 AM
pillagenburn's Avatar
Talking Re: Cams?
GM 847 ... nice and daily driveable
just get like a hotcam or 224/230 or something... if you want more later then go get it
Old Sep 12, 2004 | 03:29 AM
GhostZ's Avatar
Re: Cams?
Yup....GTP-6, very tame and driveable
Old Sep 12, 2004 | 11:32 AM
HardtopSS's Avatar
Re: Cams?
How much would I be looking at for getting no springs and cam and install? And I have to drive this to school , to home, then around town, I want to be in the mid 13's or so. What companies make these cams yall are talkin about?
Old Sep 12, 2004 | 02:05 PM
zx1216's Avatar
Re: Cams?
You should be able to get in the mid 13's easily on the stock cam, A full bolt-on car will usally run mid-low 13's or even high 12's if set up right. Just get a full exhaust, cold air intake, tune, gears and you should be on your way toward low 13's.
Old Sep 12, 2004 | 02:12 PM
HardtopSS's Avatar
Re: Cams?
http://www.fbodymotorsports.com/inc/...l?v=1&pid=1302 Is that one good or too extreme?
Old Sep 12, 2004 | 02:58 PM
unvc92camarors's Avatar
Re: Cams?
Originally Posted by HardtopSS
that usually does qualify for most people as a nice daily driver cam (a lot of people here have it so just search "hotcam" and you'll get more results than you ever wanted )
also, in your post above you mentioned getting "no springs and.."
you do plan on getting springs right?
your stockers will definately not be up to the task
Old Sep 12, 2004 | 03:04 PM
97WS6SCharged's Avatar
Re: Cams?
Yeah, that's a nice daily driver cam. And if you don't want to be ripped off, check this out.
http://www.sdpc2000.com/cart.asp?act...d=992&pid=1900
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
