cams???
Old Sep 24, 2003 | 09:10 PM
fast_TA_95's Avatar
Question cams???
i am looking for a cam that will give me about 30 horse this will include rollers, pushrodds, lifters, springs, basically the whole valvetrain. I want the car to run a little stock but loopy is fine with me, i just dont want to go to outrageous. For mods i have hooker LT's, 125 shot, hooker y-pipe, corsa exuast, holley adj. fuel press. regulator, colder plugs, msd plugs wires, 6AL ignition, Blaster coil, granetelli MAF, Kand N cai, 3.73's, 160 thermo. should i go with the hot cam or a big comp cams cam???
Old Sep 24, 2003 | 09:18 PM
curly's Avatar
contact combination motorsports and talk to them...they can steer you in the right direction. Awesome customer service!!!
D James's Avatar
well there are so many to choose from its hard to give you a direct answer, a cam selection must be well thought out. THe hotcam from what I've heard at the track doesn't lope to much, not real noticable unless your exhaust is very open like having a cutout. My cam which is a blower grind doesn't lope at all, more choppy, but even then its still pretty tame, sounds less than the hotcam, and is bigger. Looks like you should have no trouble finding one that will suit your needs, I would do a search to test the waters, cause this topic comes up everyday
Here are some soundclips that might give you an idea of what they sound like. http://members.***.net/gmarengo/
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
