Camaro LT1 Walbro 255 pressure
Old Feb 20, 2020 | 07:49 PM
zmike's Avatar
fuel pump is a Walbro 255 with Hotwire kit
Fuel pressure when primed with key on: 30 psi
Fuel pressure when primed with jumper under the hood: 40 psi
shouldn’t these read the same?
pressure bleeds down 10 psi fast then slowly to 0 psi.
i have the fuel rail pulled up with the injectors intact to check for leaks.
i have checked the FPR (stock) vacuum line for fuel and there is none.
any help is appreciated
Old Feb 20, 2020 | 11:42 PM
Re: Camaro LT1 Walbro 255 pressure
I assume the Hot Wire kit uses it's own relay. But does the “prime” connector still run power through the stock relay/wiring?
With a totally stock system, this would be the response:
While the under hood “prime” connector bypasses the fuel enable signal, in 96/97 models it passes through a normally closed switch in the fuel pump relay.
When the PCM provides 12 V to activate the pump using the relay, the bypass circuit switch in the relay opens, and the relay closes the circuit from the PCM to the relay to the pump. Possibly a problem w/ voltage loss through the fuel pump relay, or the wiring from the PCM to the relay.
Old Feb 22, 2020 | 01:48 PM
DrewHMS97SS's Avatar
You nailed it Fred. There is a plug and play connector with a relay that Y’s into the fuel pump connector, mounts next to the fuel and brake lines, then has a 12 gauge wire that connects to the back of the alternator.
Stephen68
May 21, 2016 09:08 PM
Bails098
Dec 12, 2010 06:09 PM
HIRISK
3rd Gen / L98 Engine Tech
Feb 22, 2009 11:29 PM
bluherron
12
Sep 2, 2008 12:13 PM
tanker
Jun 29, 2003 03:23 PM
