Cam Video and ?
Old Jan 1, 2004 | 09:27 PM
Larnach's Avatar
Cam Video and ?
Well here it is with the Jet Hot Long Tube's installed, running very rich, not fully tuned either. Man it was a bitch taking these things off, however I put some MAC's on and it sounds great, especially through the Hooker Catback. Anyway here it is, 224/230, mild heads.
http://www.siknor.com/LTCam.wmv
It idles pretty high so you can't hear a whole lotta loap, but now, about 3 weeks since the video, I've worked out the bugs, will put up a video later with the MAC's and DMH.
However, I have one big problem, I see oil leaking out on the sides of the block where the heads meet the block. It looks as if it drips down from the head gaskets and down the block, its happening on both sides too. I checked the back of the intake manifold, pretty clean, the valve covers are good too.
What gives?
Old Jan 2, 2004 | 01:22 AM
Spinner's Avatar
2 thumbs way up
Old Jan 2, 2004 | 01:29 AM
QCKZ28's Avatar
oil leak:
you didnt have the heads off right?
double check the valve covers.....
jesse
Old Jan 2, 2004 | 02:02 AM
Cmr0z28's Avatar
Very nice car....looks alot like mine!
I like how the door was shaking towards the end LOL
Sounds great! I love my Hooker cat-back
Old Jan 3, 2004 | 08:41 AM
Larnach's Avatar
Thanks guys, yeah about the oil leak, I did have my heads mildy ported, there is no leak from the back of the intake manifold, or from the valve covers. It doesn't make any sense to me.
I'm gonna get under there sometime this week and fix that and the tranny leak while I'm doing the EGR. I'll take some pics for a diagnosis.
Later
Old Jan 3, 2004 | 10:33 AM
funina91ss's Avatar
That video was threw the hookers open headers right? Sounded like it.
Good choice on the car by the way Let me know when you get the other clip up..
Sean
Old Jan 3, 2004 | 11:29 AM
Gripenfelter's Avatar
Until you get the oil leak sorted out make sure you run straight water not coolant or u wil spin a bearing.
If you had the heads off my guess is the heads weren't torqued down properly in steps.
Old Jan 3, 2004 | 12:48 PM
ChrisUlrich's Avatar
Yo
That sounds freakin INSANE!! What kind of exhaust you have on there?
Old Jan 3, 2004 | 01:12 PM
Spinner's Avatar
Sounds like open longtubes to me
Old Jan 3, 2004 | 02:55 PM
Larnach's Avatar
How do you figure coolant will spin a bearing versus running water?
The heads were torqued to 68ft. lbs in sequence, I used the Hayne's manual. First I torqued to 40ft. lbs in sequence, then to 68ft. lbs in sequence, then I rechecked them all.
Maybe there's a place I'm not feeling around in on the intake. I'll take a better look.
Yeahp, open Jet Hot LT's, my MAC's sound just as loud too Even better through the Hooker.
Old Jan 3, 2004 | 03:07 PM
funina91ss's Avatar
I would really check around the vavle covers I had an oil leak coming from them too and it was really hard to see it. you can even get a dye and put in your oil and use a UV ligth to see where it is coming from..
Old Jan 3, 2004 | 03:08 PM
Larnach's Avatar
Yeah its entirely possible, I haven't really checked them that well. Must be leaking on the intake side or on the back. I just got this engine bay and engine clean enough to eat on too. SOB!
DirtyDaveW
Mar 15, 2015 07:01 PM
NewsBot
Mar 13, 2015 07:15 AM
NewsBot
Feb 26, 2015 02:10 PM
NewsBot
Jan 29, 2015 07:10 PM
