cam timing
Old Dec 23, 2007 | 02:20 PM
thebufenator's Avatar
cam timing
I seem to be having a problem with the cam timing on my engine....
with the dots pointed at each other on the gear sprockets, and the opti dowel at 3 O'clock, #6 should be at TDC, right?
Mine has #8 close to TDC, just past it, and #6 isn't even close.....
Should I just take the timing chain off, align #6 to tdc, make my own "dot" to align, and then put the chain on?
Kinda confused right now........
Old Dec 23, 2007 | 03:15 PM
cnorton's Avatar
If the crankshaft sprocket dot is at the top and the #6 and #1 pistons are not at the top of their respective bores, stop and find out what is wrong.
Does the lower sprocket have multiple key-ways? If so, are you choosing the dot that is specific to the key-way you are using?
Don't make your own dots! Something isn't right.
Old Dec 23, 2007 | 03:55 PM
hmmm.........while I was sure I installed it right......I used the key way for 4 deg advanced....
my bad :P
Old Dec 23, 2007 | 05:45 PM
Good thing you found your mistake.
Old Dec 23, 2007 | 10:04 PM
yeah......and now when I crank the engine over it has a smooth feel to it....with 4 degrees retarded it didn't feel smooth at all.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
