cam timing
Old Jun 28, 2004 | 04:34 PM
Max 93's Avatar
cam timing
Is there any way to check the cam timing without pulling the timing cover? My friend did a cam swap (224/230) and the car is lacking power and only pulling about 8-10 vacuum. I am thinking the cam may not be lined up properly.
Old Jun 28, 2004 | 05:10 PM
1racerdude's Avatar
cam
Check the valve adj before you go rippin & tearing.Intake valves to tight will cause a hell of a vacuum leak.
Old Jun 28, 2004 | 05:32 PM
Max 93's Avatar
I did help him adjust them to 3/4 past zero lash.
Old Jun 28, 2004 | 05:41 PM
joeSS97's Avatar
You should go no more than 1/2 a turn.
Old Jun 28, 2004 | 05:50 PM
1racerdude's Avatar
Go to 1/4 with the feel on the push rod method.When you get them loose,tighten them down a little at a time while rotating the pushrod.You will feel a slight drag when turning--this is zero-- go 1/4 past and lock it down.Now you have to get ALL valves on the cam heel.Pull all plugs,follow ithe firing order,put your finger in each cyl in the firing order and turn it over with a ratchet on the balancer bolt and when it goes WOOOSH--it will start small with the wooosh and get more sound as the piston comes closer to the top, adjust that cyl's valves.
Follow the firing order 18436572 starting from TDC#1.
Old Jun 28, 2004 | 07:09 PM
Max 93's Avatar
why? They are stock replacement lifters. The shop manual says 3/4 turn.
Old Jun 28, 2004 | 07:28 PM
1racerdude's Avatar
Yea IF they are actually AT 3/4 turn.1/4 turn gives you some margin for error without bottoming and holding the valve open.That is what we are talking about--low vacuum--.The lifters could have varnish inside and not liking the deep adj.for the plunger.
Causing them to hold the valve open and like you said it could be the chain installation being off.I would see if the valves are correct before I spent the labor to check the chain and find out it was the adj.all along. It doesn't take but one intake valve staying off the seat to cause low vacuum.
Old Jun 28, 2004 | 09:26 PM
Max 93's Avatar
I'll try redoing them and see what happens
Old Jun 28, 2004 | 09:31 PM
1racerdude's Avatar
adj.
OK
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
