So since I have to pass visual emissions testing......
Old Jun 27, 2004 | 11:10 PM
RedRyder518's Avatar
I am on the edge of buying Pacesetter longtubes, but only one problem. I live in Houston, Harris County to be exact and they can be sticklers about emissions testing. Since I do have OBD II, I know they just plug a computer into the port and they see if there are any codes popping up. I also believe that they have a visual inspection to make sure the cats are present.
Since I would have longtubes, I would naturally want to run an offroad pipe with my setup. Most likely I would use the Pacesetter y-pipe that you can buy with it. My question being, is there a way I would be able to have a "bolt in" high flow cat for when I do emissions testing? Once I pass the test, I would be able to bolt on a straight pipe in the cat's place. Does anyone have this sort of setup?
Old Jun 28, 2004 | 02:41 PM
Guggi97_RA's Avatar
inspection harris county
I am running hooker long tubes with a y pipe and no cats. I live in Harris county and have for a long time now, but I have Ohio plates. Ohio does not require inspection so I have been floating around Houston for a long long long time now with all of my Ohio stuff.
I want to get my car inspected as well. I have an OBD1 ECM at the moment. I know I will need to get my OBDII ECM programmed in order to pass inspection, but Im not sure that will cut it. I am not sure if the computer will do a simple check for emissions related codes, or will it do a FUNCTION test?
I think I have a place that will pass me if all the computer does is look for codes. Visual inspection is another issue, as well as a sniffer test due to no cats on that car.
Anyone know how the tests actually function?
Old Jun 28, 2004 | 03:05 PM
If they are sticklers for visual, they will take one look at the long tubes and fail you. Long tubes alter the original placement of the cats (which is a violation of federal regulation), so no long tubes are "legal" anywhere in any state.
Old Jun 28, 2004 | 09:39 PM
I know that long tubes are technically not legal, but I'm sure if they look and see that I have all the EGR hookups and a cat, then they would pass me. But back to my question, does anyone have a setup with a bolt-in removeable cat?
Old Jun 28, 2004 | 09:45 PM
Tony Danza's Avatar
Regardless of if other people have it done (and I'm sure plenty do), it is a simple job for any exhaust place. Just take it to a compitent shop and they will do it for you.
David Dempsey
Mar 12, 2016 12:42 AM
NewsBot
Aug 21, 2015 09:40 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
Cam's maro
Aug 11, 2015 07:45 AM
Aug 5, 2015 08:35 AM
