Cam swap+springs Issues?? @HELP thnx
Old Apr 9, 2005 | 01:00 PM
Radd's Avatar
Unhappy Cam swap+springs Issues?? @HELP thnx
Just did a cam swap/springs and my car ran fine first time i ran it. Then i dropped a valve and had to fix everything. everything is put back together and i am having a issue with rpms. My car is a M6. My rpms are fine at idle but once i start moving the car and take it out of gear the rpms are at a high idle of 2 G + then i go back into gear and the rpms want to stay high. the rpms do not come down till i stop. what could be causing this issue?
i checked my vacumm lines and all seem fine. i replace those hard vacumm lines with rubber tubing.
Old Apr 9, 2005 | 02:31 PM
guywithaZ's Avatar
Re: Cam swap+springs Issues?? @HELP thnx
I don't know if it will help but I never replace hard lines with rubber tubing they colapse under suction and tend to rot away from the inside given the right circumstances...
Old Apr 9, 2005 | 08:10 PM
Radd's Avatar
what do i do to replace them without going through the dealership
armedtrigger
Feb 24, 2015 08:30 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
donot_4get
Sep 14, 2002 08:03 AM
