Cam Swap part advice
From a stock engine, you would have to swap:
Besides the optispark itself (GM p/n 1104032), you need:
- 95 or later timing cover [1995 front cover (includes round seals) GM p/n 12552426]
- late model cam (or have your cam modified by drilling the hole in the front to the proper size [.500"dia. X 1.0625" deep] and a longer dowel pin added
- 95 and later optispark electrical harness GM p/n 12130319 (cheaper alternatives available from other sources)
- optispark vacuum harness GM p/n 12555323
- vacuum fitting [GM p/n 14082470] or "tee" to provide vacuum for the opti
- 95 or later timing gear set or at least cam gear (GM p/n 10206039)
- timing cover gasket GM p/n 10128293
- water pump gaskets [2] GM p/n 10128343
- intake manifold gaskets if you are pulling the cam GM p/n 12524653
