Cam Swap
Old Jul 10, 2003 | 02:32 PM
BST434's Avatar
Cam Swap
DOES ANY ONE KNOW IF YOU CAN SWAP THE CAM WITHOUT PULLING THE MOTOR , LIKE REMOVEING THE RADIATOR , WILL IT GIVE YOU ENOUGH ROOM , THE ONLY REASON I DO NOT WANT TO PULL THE MOTOR IS BECAUSE OF HOW THE EXAUST WAS INSTALLED I CANNOT PULL THE MOTOR OUT THE BOTTOM WITHOUT CUTTING THE EXAUST
Old Jul 10, 2003 | 02:34 PM
White_94_TA's Avatar
Re: Cam Swap
God i love when the noobs ask questions. Yes, you can install the cam with the engine in the Car. Installed my Hotcam and all i removed was the Fan/Radiator assembly.
Old Jul 10, 2003 | 02:35 PM
Blue96z28's Avatar
The answer is yes, you can do a full CAM swap while in car. I believe you need to remove the radiator and kind of **** the condensor a little. And remove the bracket that holds the hood down.
Old Jul 10, 2003 | 02:36 PM
BST434's Avatar
THANKS , IT IS GOOD TO GET A SIMPLE STRAIGHT FOWARD ANSWER
Old Jul 10, 2003 | 02:54 PM
BTW, stop yelling. [caps]
Remove the radiator and move the a/c condenser out of the way. That's all I had to do. There was just enough room.
Old Jul 10, 2003 | 02:57 PM
BST434's Avatar
thanks sorry for the caps , programs i use at work require caps , you know you get in the habbit
Klypto
Mar 23, 2016 09:05 AM
jj_burchiel
Mar 5, 2015 07:05 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
