Cam Swap
DOES ANY ONE KNOW IF YOU CAN SWAP THE CAM WITHOUT PULLING THE MOTOR , LIKE REMOVEING THE RADIATOR , WILL IT GIVE YOU ENOUGH ROOM , THE ONLY REASON I DO NOT WANT TO PULL THE MOTOR IS BECAUSE OF HOW THE EXAUST WAS INSTALLED I CANNOT PULL THE MOTOR OUT THE BOTTOM WITHOUT CUTTING THE EXAUST
Re: Cam Swap
Originally posted by BST434 DOES ANY ONE KNOW IF YOU CAN SWAP THE CAM WITHOUT PULLING THE MOTOR , LIKE REMOVEING THE RADIATOR , WILL IT GIVE YOU ENOUGH ROOM , THE ONLY REASON I DO NOT WANT TO PULL THE MOTOR IS BECAUSE OF HOW THE EXAUST WAS INSTALLED I CANNOT PULL THE MOTOR OUT THE BOTTOM WITHOUT CUTTING THE EXAUST |
The answer is yes, you can do a full CAM swap while in car. I believe you need to remove the radiator and kind of **** the condensor a little. And remove the bracket that holds the hood down.
THANKS , IT IS GOOD TO GET A SIMPLE STRAIGHT FOWARD ANSWER
Originally posted by BST434 THANKS , IT IS GOOD TO GET A SIMPLE STRAIGHT FOWARD ANSWER Remove the radiator and move the a/c condenser out of the way. That's all I had to do. There was just enough room. |
thanks sorry for the caps , programs i use at work require caps , you know you get in the habbit
