Cam suggestions...
Cam suggestions...
Alright, I currently have a 306 cam in my 95 Trans Am and want to know if theres a better one out there that will get me down the track faster.. I have a 355, Lt4 heads and intake gasket matched so they flow alittle better, but not alot, 3600 stall, 30lb injectors, 1.6 rr, 58mm TB, nitrous and a 3.73 gear, but prolly change.. Thats the most important mods.. Whats some opinions, keep or is there something better? This is only for this summer, so dont want to spend $350 on a custom one for 3 or so months..
I would just keep the CC306, there are not many better options for shelf cams, unless you want to step up to something a little more extreme like the GM847. If you are going to go through the hassle of installing another cam, I would just spend the extra money and get a custom one made.
What times/mph are you currently running? What/where is your peak torque occuring? You might be able to use more converter and gear with that cam...You could probably just tweak what you have a little bit and be very happy...
--Alan
--Alan
Heres my dyno graph, I made first 2 on motor and 3rd on 75 shot.. I dont see why it dropped power at 5600 except maybe my tachs off aways and thats where I let off or its taking timing out..?? Also have around 11 to 1 compression..
what valve springs you running and why didn't you twist it up higher?....where is your limiter set?
its kind of hard for me to see the mumbers but its says your max tq is ar 5000+
I have Comp cams 987 double valve spings, suppose to be good for .600 lift, and my rev limiter is set at 6800 I believe, pcmforless did it, and it shifts at 6500 on my tach, which is prolly alittle lower.. I believe thats where that had me shut it down about..
