Cam Spec Questions
Old Oct 23, 2006 | 10:30 PM
  #16
johnny3986's Avatar
Re: Cam Spec Questions
Originally Posted by seawolf06
You really should. At least get rid of the stock stamped ones, they're pretty weak. I got comp pro mag 1.6 RR.
Yeah, the stockers were getting deep 6'd in this switch, but I didn't know if 1.6rr with the Extreme Energy cam described was going to be too much lift....AND since I didn't know how to check the valvetrain geometry (measurements and such), I just wanted to check.
If 1.6rr were too much, I was going to use 1.5rr
What are the blue racers??
Old Oct 24, 2006 | 08:23 AM
  #17
chrism400's Avatar
Blue Racers used to be made by Wolverine which was acquired by Crane. The are a lower cost option from Crane and work perfectly well while fitting under the stock valve covers. 1.6 's will be fine as there is PLENTY of piston to valve clearance with a stock setup and 503 cam.
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
