This cam with this set of heads?
Old Apr 11, 2004 | 02:12 PM
96formulabird's Avatar
I just got my heads back from Lloyd and was wondering what you guys think about my cam selection for this set of heads. Right now I have a XE 224/230 with a .536”/.544” lift on a 112 lsa. My main question is how much power, if any, am I leaving on the table with this cam over a custom grind or larger cam? Here’s the flow numbers for the heads:
.200 134.5 100.4
.250 160.7 124.1
.300 188.9 134.6
.350 215.4 150.7
.400 233.9 160.8
.450 248.7 171.4
.500 256.5 177.6
.600 261.4 183.8
.650 262.4 185.6
I wanna keep the revs around 6100/6200 rpms which is one of the reasons I chose this cam. Stock valve sizes BTW.
Old Apr 11, 2004 | 05:43 PM
rob97ss's Avatar
Before you start looking for a bigger cam you should ask yourself a few question first.What is the car mainly used for,the bigger you go the more issues you will run into.
Old Apr 11, 2004 | 05:57 PM
bunker's Avatar
That cam is tiny because an XE grind of that duration is acctually a very small cam when compared to a slow ramp cam like a cc305, this XE would be considered much smaller then a cc305 but make the same power to 6k rpm where it will just plummet down, don't rev past 6k MAXXXXX!!! or YOU WILL slow down!
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
