Cam selection question???
Old Mar 10, 2007 | 08:05 PM
LALT1's Avatar
I am pretty sure but wanting to verify, can you not use a cam for any 87+ SBC in a LT1?? So long as it Requires thrust button and wear plate?? Just wanting to verify this. Thanks for any help. it is a 95 model motor with center dowel for opti. I am hoping Bret will contact me on a custom, but needing to do something fairly quick.
Old Mar 11, 2007 | 01:08 PM
deepstage69's Avatar
I dont see why you couldnt, only difference is the dowel. If you got an 87 up cam, you would have to pull out the dowel, and put a longer one in.
Old Mar 11, 2007 | 02:13 PM
LALT1's Avatar
My only problem I see is the center spline for the dowel for the opti. I will call Comp tomorrow I guess.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 17, 2014 11:00 AM
Noenav
Dec 6, 2014 07:35 PM
