Cam selection on my 396"...what my local engine guy told me...
Old Apr 25, 2005 | 11:59 PM
  #16
SStrokerAce's Avatar
Re: Cam selection on my 396"...what my local engine guy told me...
http://web.camaross.com/forums/showthread.php?t=357018
Thread Exerpt....
2. AVOID "OVERLOAD": Increased load always means reduced service life. Want 50% more thrust from a jet engine? Ask Rolls Royce or G.E. and they'll tell you to expect about ¼th the service life between overhauls. Similarly, employing drag race valve springs in the 900, 1000 to 1100 lb. Range will reduce the life of your roller bearings between rebuilds much the same as will employing high-impact roller cam profiles.
Point highlighted for a reason....
Some of the TK's are good lobes for some situations but this needs to be taken into account as well.
Bret
Old Apr 26, 2005 | 12:02 AM
  #17
Originally Posted by JustNO
LOL So I just got mail from my camshaft expert.. He said to me that I should go 236/248 555/533 110lsa What are you saying for this shiiiit?? he knows that I will go 200 wet shot nitrous and also I drive every day,not a drag car.. Suggestions are very bad these times
I can guess who that is.... depending on the RPM and application that might not be to far off.
Bret
Old Apr 26, 2005 | 03:16 AM
  #18
JustNO's Avatar
ohh come onnn! 110 lsa?? I never heard anyone use nitrous with 110 lsa camshaft..(I know it should be at least 114 lsa to use nitrous shot) Also There is something wrong 555/533.. Why exhaust lift is smaller than intake's?
Old Apr 26, 2005 | 05:22 AM
  #19
rskrause's Avatar
Moderator
I undertand the irony in the previous post. But to be sure no one gets confused, somewhere the idea has gotten started that a "nitrous cam" needs a big LSA. This is not the case.
rich
Old Apr 26, 2005 | 06:47 AM
  #20
Jason Short's Avatar
CANTONRACER, having built a few NA strokers I would recommend 2 things to you. First, dont listen to what the "cam help" line guys say at Comp......I am not convinced that most of them know what they are talking about based on my experience and others.
Second, make life easy and call Cam Motions for a cam. They are very, very good and the majority of fast LT1 cars run their grinds. I have had nothing but great results with their cams in my engines. At this level, dont chance a pig engine by going with an "unknown" cam based on the suggestion of those who HAVE NOT built LT1 motors like this.
Jason
Old Apr 26, 2005 | 06:56 AM
  #21
Mindgame's Avatar
Agreed!
Jason
Jason's right. The nice thing about CM is that the help you get is much more "personal". If you had a guy at Comp.... someone who was in on the cutting edge of their develop... you could get sound advice. Bret and his pops know the right people at Comp and that's worth a lot for sure.
110 can work very well on nitrous, and often does. It's all about the other stuff that determines whether it's right for you. For example, a cylinder head with a poor intake/exhaust flow ratio might like a wider lsa but that's something to get across with a reputable cam/valvetrain designer. Find someone you can trust and let them make a decision... just like you would if you had cancer and were looking for the best doctor. By all means, get a 2nd or 10th opinion, but leave in the hands of the experts.
-Mindgame
Old Apr 26, 2005 | 11:29 AM
  #22
JustNO's Avatar
I just built my whole engine at thunderracing..Its an assembly of top notch quality parts (oliver,lunati,diamond). I spent lots of $$$$ and off course want everything perfect.. Paul from Thunder is the guy who is interested with everything about assembly of engine.. I use 210cc AFR competition Heads (with 2.08 intake 1.60 exhaust valves) Valvetrain is for a solid roller cam ,I will change it for a hydrolic Roller cam.. And yesterday he said his cam experts would suggest that specs of cam (236/248 555/533 110lsa) I don't know should I trust his cam experts. I trust Paul ,but don't know his cam experts.
(sorry for the spelling and thanks for all of your posts)
Old Apr 26, 2005 | 12:09 PM
  #23
CANTONRACER's Avatar
I called Cam Motions...told them what my combo is, etc.
The cam that Cam Motions recommended:
@.050" 259/264, lob sep 108, center line 104, lift .683/.670, very aggressive lobes
Spring pressures of 220/550.
Basically the same cam.
I just had my local guy order it for me with a .900" small base circle. Like I said, I will try it for a season and see if I like it.
Thanks for the input guys.
Old Apr 26, 2005 | 12:18 PM
  #24
JustNO's Avatar
Hollly cr..p Its a huge camshaft with 108lsa??!! I can't believe thats for a daily drive.. Just can't believe.. Drive daily and tell me then I will believe
Old Apr 26, 2005 | 12:28 PM
  #25
It is not a daily driver in any regard.
Old Apr 26, 2005 | 03:50 PM
  #26
rich
Yeah I can't say that enough.
It's not a function of LSA EVER!!!!!!!!!
Old Apr 26, 2005 | 08:14 PM
  #27
Denny McLain's Avatar
Race only even with a good driving tune. Depends upon what ya want, but it will buck like a bucking bronko during daily driving.
Bet it's one fast fo mo if ya got the heads to go with it.
Old Apr 26, 2005 | 08:26 PM
  #28
rskrause's Avatar
Moderator
Forgive the yelling in advance BUT IT WOULD HAVE BEEN 'NICE' IF YOU TOLD US IN THE FIRST PLACE IT WAS FOR A RACE CAR!
Rich
Old Apr 26, 2005 | 08:47 PM
  #29
Being "not a daily driver in any regard" = drive it once in awhile on the street, primarily race it at the track type of car.
Old Apr 27, 2005 | 08:52 AM
  #30
WS Sick's Avatar
Yeah, but will you give rides for free...lol
oldschool
Feb 9, 2016 09:21 PM
Dec 17, 2014 11:00 AM
cmdeshon
Dec 12, 2014 10:51 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
