cam selection
Old Jan 16, 2005 | 07:19 AM
lt1zpwr's Avatar
cam selection
which cam can i get that will give me a lil power but still pass emissions? i was considering the lt4 hot cam kit and suggestions i also saw that crane has an emission legal cam kit think this is any good, thanx
Old Jan 16, 2005 | 01:03 PM
96m6lt1's Avatar
Re: cam selection
there are so many cams out there that will fit your description if money is tight you simply can't beat the hotcam at 175.00,whereas the others range from 235.00 on up,valve springs-i prefer to go to a company like comp cams they are worth the few extra bucks,get the HD lt4 timing set,make sure to get the things that will compliment the cam:1.6 rockers,headers,svo 24lb or racetronix 32lb and get it tuned by one of our capable vendors.oh yeah invest in a set of drag radials.
Old Jan 16, 2005 | 01:04 PM
Mac 93 Z's Avatar
Re: cam selection
You might want to check the www.easternfbody.com website (EFA). They have alot of guys over there from Maryland and I'm sure they will lead you in the right direction . IMHO ,you should be fine with the LT4 Hot Cam and CC305 if emissions is the issues. Good luck.
Old Jan 17, 2005 | 11:48 AM
RealQuick's Avatar
Re: cam selection
I pm'd you about a cam...
Old Jan 17, 2005 | 12:33 PM
hotrod18_69's Avatar
Re: cam selection
CC 305 would be a good choies. Do a serach and should come up with some good results.
Old Jan 17, 2005 | 02:01 PM
Bersaglieri's Avatar
Re: cam selection
Call Combination Motorsports and have them set you up with a cam that will pass emissions yet meet your personal needs and expectations.
-Dustin-
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dec 17, 2014 11:00 AM
Black Sunshine/ 00SS
Jul 29, 2002 11:57 PM
