Where to find a SFI approved flexplate?
Old Nov 30, 2004 | 11:28 AM
kamba93lt1's Avatar
I am looking for a SFI approved LT1 crank flexplate. An internal balanced one. I know of the B & M and TCI external balance(the one with the weight on it). I am wondering if anyone makes one without the weight. Must have the 10.75 bolt pattern for LT1 cranks.
Ken
Old Nov 30, 2004 | 12:21 PM
BlownF1's Avatar
Re: Where to find a SFI approved flexplate?
AFAIK, you can just remove the weight and have it rechecked for zero balance. I'd call B&M if you need more info or are looking for a part number of one that comes that way to start with, but that's an option at least. I just went through this trying to find one with a weight...
Old Dec 1, 2004 | 12:16 AM
1racerdude's Avatar
Probe can get you one without breaking the bank.As already said you can remove the weight and "0" balance it.
Make sure they know it's for a late LT-1 and not the one from the late 70's or early 80's because it won't work.
Old Jan 16, 2005 | 10:34 PM
SILVERZZ28's Avatar
won't work as in how? Please explain.....
Old Jan 16, 2005 | 10:42 PM
1racerdude's Avatar
The early and late ones have different thickness mounting area.One is thicker than the other,which leads to a lot of extra work.
Old Jan 16, 2005 | 10:43 PM
SILVERZZ28's Avatar
Sp your saying clearance will be wrong?
Old Jan 16, 2005 | 10:48 PM
Loadre's Avatar
http://web.camaross.com/forums/showthread.php?t=307423
Old Jan 16, 2005 | 11:08 PM
SILVERZZ28's Avatar
yep and...
Old Jan 17, 2005 | 01:38 PM
quickSS's Avatar
Also ATI in Baltimore Maryland, (you know the company that makes the torque converter manufacturing machines that many companies use to build torque converters).
They also make SFI late model 1 piece rear 153 tooth flexplates.
neutral balance or counterweight.
call them up at 800-284-3433
hth
Karl Ellwein
Edit: found the part number for you 915533 chevy 86' and up one-piece rear 153 tooth "internal balance". $169.00 bucks.
Old Jan 17, 2005 | 03:44 PM
Loadre's Avatar
Originally Posted by SILVERZZ28
yep and...
For more information about TCIŽ's SFI Flexplates contact your nearest TCIŽ dealer or visit us online at www.tciauto.com
Your welcome smartass.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Hurin
Dec 13, 2014 07:38 PM
squinn
Aug 4, 2002 01:06 PM
