Cam Question
Old Mar 14, 2013 | 12:33 PM
Mr_WoodZ's Avatar
Cam Question
Have a 95 z28 with listed mods and a Lunati 54760LUN Cam. I'm debating a cam swap. Would the CC503 be worth the cost to upgrade. It would cost me about 250 to have cam installed.
Cam specs are:
Brand: Lunati
Part Number: 54760LUN Part
Basic Operating RPM Range: 1,500-5,300
Intake Duration at 050 inch Lift: 213
Exhaust Duration at 050 inch Lift: 219
int./219 exh. Advertised Intake Duration: 279
Advertised Exhaust Duration: 287
Advertised Duration: 279 int./287
exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.447 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.471 in.
Valve Lift with Factory Rocker Arm Ratio: 0.447 int./0.471 exh.
Lobe Separation (degrees): 112
or
Brand: COMP Cams
Manufacturer's Part Number: 07-503-8
Basic Operating RPM Range: 1,800-5,800
Lift: 224
Lift: 230 Duration at 050 inch
Lift: 224 int./230 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 281
Advertised Duration: 276 int./281 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.503 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.503 int./0.510 exh.
Old Mar 14, 2013 | 02:56 PM
KW Baraka's Avatar
Re: Cam Question
Hard to say whether it'd be 'worth it' or not.
What's 'worth it' to you may be a lot different from what's 'worth it' to me.......and vice-versa.
But.....the 503 is a significant enough of an upgrade over your current cam that in, addition to the cost of the cam and the $250 install......you'd also need to find good pricing on PCM tuning......and a probable valve sping upgrade.
KW
Old Mar 14, 2013 | 08:58 PM
Mr_WoodZ's Avatar
Re: Cam Question
The car has all the supporting mods already and pcm will be tuned regardless of the decision. I'm not very knowledgeable in this area and I pretty much was hoping to find out if someone could give an estimate of the difference in hp for the two.
Old Mar 15, 2013 | 09:33 AM
KW Baraka's Avatar
Re: Cam Question
Well.....you really haven't provided enough information for a 'good' estimate to be given.
What can you tell us about your setup?
Engine.....compression ratio.....Quench (if you know it)?
Heads and valvetrain.....what are the specs? Aftermarket, ported, stock?
Intake......stock or ported?
Throttle Body......how many millimeters.....aftermarket......stock?
Exhaust......just shorties (brand) and a muffler upgrade?
Without this info, giving you any kind of estimate wouldn't even amount to a decent guess.
KW
Old Mar 15, 2013 | 11:53 AM
bw_hunter's Avatar
Re: Cam Question
While what KW said is true, his comments speak to what your engine cold do with each of these cams. If you look at it theoretically though and make the assumption that everything is equal with the heads, etc, I'd think the Comp Cams piece would be worth about 25 more rear wheel horses than the Lunati just by virtue of the longer duration and higher lift.....
Old Mar 15, 2013 | 12:40 PM
slick1hunting's Avatar
I will add another thought to what has been said. If you did the comp cam you would see even greater increase with head work in the future if you chose not to swap cam again. My guess is the tuners base tune would probably be easier with it as well as its a popular choice for an off the shelf grind.
Posted from Camaroz28.com App for Android
Old Mar 15, 2013 | 02:53 PM
englundjd's Avatar
Re: Cam Question
The Comp cams 503 is a very popular cam for people with stock casting heads. good driveability and decent power for the cost.
as stated your going to need a tune, and probably new valve springs.
you would probably have more fun if you put different gears in the rear end like a 3.90 or 4.10 (assuming your stock geared) ...it would be a more "noticeable" mod.
Old Mar 15, 2013 | 09:07 PM
Mr_WoodZ's Avatar
Re: Cam Question
I did not mean the hp of my setup when i asked for hp estimates. I was referring to one cam compared to the other under the same setup. Sorry I was not clear. The car does have stock gearing and hopefully 4:10's in the near future. The car is not a daily driver but I would like to keep it driveable as i would like to cruise around and drive it to the track on occasions.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
