Cam Question
Old May 17, 2006 | 10:45 PM
97Z2830thAnn's Avatar
Cam Question
Hey everyone, i have a cam question. I have a 1997 z28 and i want to throw probably a le1 package in there. The problem is I have 97,000 miles on my car. Is this a good idea, or not? If i was to rebuild my engine what kind of components should i be looking to replace and what do you think they would run? I am not looking to go to crazy on this, just get around 350 HP. I did 260RWHP stock. Do you think i could get 350RWHP with an LE1 package and supports mods? Let me get everyones opinions. Thanks guys.
Old May 17, 2006 | 11:00 PM
OrbitalChris's Avatar
Re: Cam Question
yeh, you could def get 350, id just get a hotcam kit, as long as you support it right with the rest of the valvetrain itll be fine--good luck!
Old May 17, 2006 | 11:02 PM
Re: Cam Question
Do you think i would need to rebuild then? Or should i be safe with my engine?
Old May 17, 2006 | 11:16 PM
Re: Cam Question
It's a crap shoot. If you have money, go through the engine. If not, you can take your chances. You might be ok, might not.
Old May 18, 2006 | 12:20 AM
Javier97Z28's Avatar
Moderator
Re: Cam Question
Agreed, it's a crapshoot on whether it will go or not.
Don't do it unless you can afford to do a rebuild if something *does* go wrong and the engine goes south.
370+ rwhp has been attained by LE1 setups.. so yes, 350 is quite doable.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
