Cam question
Old Feb 22, 2004 | 03:54 PM
meangreen95z28's Avatar
Cam question
I want to get a new cam. I will leave the heads stock for now, but after the cam swap probably will do 4:10 gears in the rear. What is a good cam that will make good power on stock heads?
Old Feb 22, 2004 | 04:16 PM
FacelessZ's Avatar
my XE 230/236 .112 lobe separation
.555/.566 at 1.6
I was going to use it on my stock heads but I got a ticket so it needs to go...$200 shipped...lobes are in awesome condition as well as the dowel.
Old Feb 22, 2004 | 04:35 PM
Bersaglieri's Avatar
Nice promotional post Faceless
Good cams for stock heads IMO: Comp cams XE 218/224 , XE 224/230 , CC305, Hotcam... you can use bigger ones but only if you look to get new or P&P heads in the future, this is just my opinion.
Old Feb 22, 2004 | 04:38 PM
FacelessZ's Avatar
Did you like that action? Heh...
Old Feb 22, 2004 | 04:42 PM
Yes I did, are you a marketing major?
Also, alot of cam companys recommend gears/stall/full exhaust and cold air intake before the addition of a cam. I bet you have a M6 with those 4.10s so it looks like youll be set to go with the gears.
-Dustin-
Old Feb 22, 2004 | 04:44 PM
FacelessZ's Avatar
nope I cut open dead people...
all of this is recommended for the best output from a cam, but isn't necessary. supporting valvetrain IS necessary in order to run a cam though...
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
