Cam question
Old Jan 5, 2004 | 07:51 PM
rome856's Avatar
Cam question
I have a mostly stock 96 Z28 A4, how hard is it to change the cam? Do you have to lift out the engine?
I would like to get it in the high 12's/ low 13's, is this the best way as far as expense and being a daily driver.
Thanks again for your help.
Old Jan 5, 2004 | 08:01 PM
97WRAITH's Avatar
It is not that difficult if you have any automotive expereince and the right tools.You do not nee to pull the motor.There are alot of install guide the some of the board members have put together.I think shoebox has one and also brent franker.Do a search.I would recommend doing headers,catback and a cold air so get the max power out of the cam also if you can swing it get your heads ported and your pcm tuned.If you just want to run low 13's high 12's get all the bolt ons and you should be there.good luck.
Rob.
Old Jan 5, 2004 | 08:26 PM
Kain's Avatar
I wouldn't recommend getting a cam until you've done converter/gears/headers.
With those, and other bolt on's I ran 12.9's alone.
Old Jan 12, 2004 | 02:18 PM
rome856's Avatar
I currently have a Random Tech 3" cat-back, SS functional Ram air hood, de-screened and polished MAF, 160 stat, SLP manual fan switch, and run synthic oil in everything.
My best run to date is a 14.002 at 98 mph with a 2.0 60ft.
I have been told that headers will not make that much of a difference, that free flow cats would be a better add-on.
As for gears and a converter, will 3.73's and a 2800 stall do the trick? do I need to add a trans cooler ?
I was planning on having Fast Chip do my reprogram, they just did a chip for my dad's vette and he gained 3 tenths
I would like to get in the 12's by the summer, what should be my next purchase?
Do I need to worry bout suspension yet? ex. torque arm, control arm
Thanks again for your thoughts.
Old Jan 12, 2004 | 05:25 PM
97WRAITH's Avatar
With all the bolton's,3.73's and a converter you will be in the 12's with a drag radial.
Old Jan 12, 2004 | 05:51 PM
rome856's Avatar
Sorry I'm alittle slow
Which bolts on do you mean? headers? Roller rockers?
Old Jan 12, 2004 | 05:57 PM
97WRAITH's Avatar
Tune up.(plugs,wires),Free mods,Cold air,headers,cat-back,lower control arms,remove front sway bar,gears,stall,drag radials.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
