Cam Owners Inside!!!
Old Nov 30, 2003 | 03:21 PM
WrecklessZ's Avatar
I did so researching and i see some people blowing there trannys after Cam install I can't have that happen to me so what the best Converter 2400-300 stall. The cams I'm thing about are the cc305 or the XE 224/230.
Old Nov 30, 2003 | 03:27 PM
atljar's Avatar
Dont think its the convertors so much as the clutches. High rpms in 4l60e = death wish.
PPI (vig) makes the best convertor IMO. Machined billet cases etc. As for stall speed, you start hitting 2800+ you are likey to have no shift issues on hard launches. People are going to jump in here and say "XXXX" has a fix for it, but i have yet to see any proof.
Old Nov 30, 2003 | 03:34 PM
FastZinTennessee's Avatar
Invest in a nice tranny cooler and shiftkit. I have had good luck with the B&M 24,000 lb rated transcooler(summit- $55) and the B&M street/strip shift kit. I'm running a midwest converter.
Old Nov 30, 2003 | 03:49 PM
funina91ss's Avatar
Originally posted by atljar
[B People are going to jump in here and say "XXXX" has a fix for it, but i have yet to see any proof. [/B]
Madwolf has a fix for it Proof BTW mine is a 224/230 with a 3,200 stall I did have the high stall problem.
Old Nov 30, 2003 | 04:04 PM
atljar's Avatar
3200 is so close still even though you had the no shift before. Many times you can "tweak" it to shift. Show me 3500+ stalls on a 1.7 or less 60" and i will say thats proof Do you know if he found a stall speed table as ed wright was claiming, or is he just playing with known tables?
However, thats a sweet video.
Old Nov 30, 2003 | 04:07 PM
funina91ss's Avatar
well we tried the "tuneing fix" the first time with no luck . I am running obd2 now and it shifts like a dream best 60ft so far is a 1.54
Old Nov 30, 2003 | 04:13 PM
WrecklessZ's Avatar
So a tranny cooler and a converter. Where do I find a converter??
With the stall speed whats the limit for a daily driver with alot of highway driving??
Old Nov 30, 2003 | 05:15 PM
atljar's Avatar
OBD2 isnt a fix you silly cracker Thoe computers are just faster and can take the higher stall.
Old Nov 30, 2003 | 07:56 PM
funina91ss's Avatar
as long as I delt with that problem, it is a fix in my book.
I drive my car everyday in town and interstate both,only bad thing about the stall is it kills gas milage.
The times in sig are with a 175 shot stock bottem end Cheaply rebuilt 4L60E and a 10 bolt with 3.23 gears
Old Nov 30, 2003 | 09:55 PM
Larnach's Avatar
Your 224/230 sounds a lot different than mine in the video. I have a lot of lope, need to get it tuned a bit, but the thing flys! Hopefully I adjusted the valves properly.
Going tommorrow to get the y pipe put on, will make it a lot easier to diagnose any problems because I seem to get a little hesitation in the low RPM's... most likely retard from the long tubes vibrating the crap out of the car.
Old Nov 30, 2003 | 11:06 PM
www.raceconverters.com
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
rjc1629
Jan 27, 2015 10:46 AM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
