Cam Number Decryption. Help? :D
Old May 28, 2010 | 10:51 AM
FastandBlue's Avatar
Okay, had to use a snazzy title to get you here. :P jk jk. But seriously, I don't know a whole lot about cams. Can someone explain what the below numbers/specs mean? Thanks!
Lift: .510/.510 dur @ .050 220/230 LSA: 114
RPM operating range 1500-5500 Part #07-305-8
Old May 28, 2010 | 11:18 AM
Start with this:
http://www.compcams.com/Technical/TimingTutorial/
Old May 28, 2010 | 11:21 AM
Perfect! Thanks!
Old May 28, 2010 | 01:16 PM
DAVE00's Avatar
Originally Posted by FastandBlue
Perfect! Thanks!
FWIW - That is the CC305 cam and it is a very good cam for a stock setup with upgraded springs of course. I ran that cam in my 383 for many years and it is a good producer (very mild for a 383 I know). Emissions friendly (if you need to pass) and makes good power down low. However, it is pretty old tech and there are many new cams out there that produce more and will work better if you plan on future mods like ported heads, intake, headers, etc... The CC503 is one and it is probably best to go with a custom grind if you really want to get exactly what you are looking for based on your plans. Good luck.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
parkers Z28
Mar 11, 2016 08:14 PM
grabbem88
Feb 22, 2015 11:16 AM
