This Cam? My setup?
Old Jun 21, 2003 | 01:20 PM
MadMaxz28's Avatar
This Cam? My setup?
shooting for 430-450 rwhp 10/11sec NA mostly street car! i made 401rwhp with my 236/242xe cam(still needs good tune)... other then changing valve springs what else would help my setup? should i have enough clearence with flat pistons?
cams:
224/230 duration @ .050", .567"/.584" lift with 1.5 rockers, .605"/.622" lift with 1.6 rockers.
230/236 duration @ .050", .584"/.585" lift with 1.5 rockers, .622"/.624" lift with 1.6 rockers.
Old Jun 21, 2003 | 01:30 PM
twells's Avatar
Re: This Cam? My setup?
cams:
are you wanting wanting to switch cams?? i'm confused
Old Jun 21, 2003 | 02:32 PM
MadMaxz28's Avatar
yes im wanting to switch to a cam i can make more power with. with the same street manners. just wondering your thought on 600+ lift cams and making more hp. which springs should i use for .625 lift? those new comp poly springs?
Old Jun 21, 2003 | 02:48 PM
kmook's Avatar
Advanced Tech Moderator
This question should be posted in LT1 Tech, moving for you...
Also please edit your sig to comply with the 5 line rule....
Thanks bud.
SpeedJunkee
Apr 23, 2015 09:51 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 08:12 PM
Cam's maro
Jan 30, 2015 09:21 PM
