Which cam for my 383 Stroker
Old Jan 23, 2004 | 02:25 PM
Zepp's Avatar
Alright, I need your help here. I have currently a 383 Stroker, comp 305 cam, stage 3 cnc/P&P heads and Hooker LTs. It only has about 5,000 miles on it. I have been very happy with my current setup but feel that I am leaving too much on the table with the smaller cam. I would have went with the larger cam but I had stock heads at the time the motor was built.
Now, I am thinking about going to 100-150 shot of nitrous. Also, I am thinking about going with a bigger cam.
Should I stay with the current cam, Is it worth changing out?
If I do change the cam, what should I throw in there. GM847, Comp 306, Custom grind? What is a good nitrous cam?
I am just not sure if the cam swap would be worth it or not. I will be paying a shop to replace it if I do.
I drive this car as a daily driver to work as well as go to the strip once or twice a month.
Thanks for your help.
Old Jan 23, 2004 | 02:46 PM
CANTONRACER's Avatar
Things to think about...
compression...
head flow...
gearing....
auto? manual?
who is going to tune it...
Old Jan 23, 2004 | 03:20 PM
Zepp's Avatar
compression...
head flow...
gearing....
auto? manual?
Compression is 10.3.1
Heads are supposed to flow 270-280 (More performance Stage 3)
Manual 6 speed with 4.10 gears, Moser 12 bolt, 31 spline, Eaton posi
I have a local speed shop do my tuning for me. It will be going on the dyno for some tuning when I'm done with these mods.
Old Jan 23, 2004 | 03:43 PM
fastcamz28's Avatar
A custom cam specific to your goals/ engine specs or CC306! Just my 1/50th of a dollar!!
D1SC383LT4
Jan 1, 2016 01:56 PM
Rde Bandit
Mar 21, 2015 10:17 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
