Cam and Lifters..
Old 02-22-2006, 12:59 PM
Sdimein's Avatar
Cam and Lifters..
Kinda a newbie but just a quick question.. I plan on buying the Hot Cam Kit and also need to replace to lifters.. what lifters do i get and where can i order them from?? Also, i need to replace to oil pump.. any oil pump that should be preferred over any other? If i get the kit, do i need new fuel injectors or anything or can it wait if i dont have the cash at this moment.. ?
Sdimein is offline
Old 02-22-2006, 01:32 PM
Moderator
Javier97Z28's Avatar
Re: Cam and Lifters..
Stock injectors are fine for a hotcam.
If your mileage isn't too high and your lifters aren't damaged for any reason, you can reuse them. Over 100k I'd probably replace 'em while I was there.
As far as what to replace them with, I'd go with Comp OEM style lifters.
Javier97Z28 is offline
Old 02-22-2006, 01:43 PM
RamAir95TA's Avatar
Just a quick question....why do you believe that you need to replace your oil pump?
Crane also makes OEM lifters too, not just Comp.
RamAir95TA is offline
Old 02-22-2006, 06:48 PM
Sdimein's Avatar
This is for a 95 camaro... What link could i find those lifters at ?
Sdimein is offline
Old 02-22-2006, 06:53 PM
RamAir95TA's Avatar
Thunder Racing carries the Comps.
And what about your oil pump?
Old 02-22-2006, 07:02 PM
Sdimein's Avatar
Well.. i dont know yet but some guy was going to take the pan off tomorrow and check the bearings and crank saying that if there is some sort of oil problem that we would need to replace to oil pump.. not sure yet, but i dont think we will
Sdimein is offline
Old 02-22-2006, 07:08 PM
96capricemgr's Avatar
Honestly since by your own admission you are a newbie I strongly encourage you to do a lot more reading before you buy anything. Newbies gravitate to the HOT cam one because the magazines talk it up and two because SSSSOOOOOO many have gone with it before them many out of shear ignorance. So many people go with it before even considering anything else might actually exist that it keeps getting more press and the vicious cycle of ignorance keeps spiraling out of control.
I am not saying it is a bad cam or that all that use it don't know what they are doing. Just that there are A HUGE NUMBER of other good choices out there that deserve attention before you decide on this or any other one.
96capricemgr is offline
Old 02-22-2006, 07:16 PM
1racerdude's Avatar
Put a stock oil pump back on it.
Reuse your existing lifters if they are in good shape. No need to buy any replacements as the factory ones are as good as is out there.
1racerdude is offline
Old 02-22-2006, 07:40 PM
FastZinTennessee's Avatar
So if there is a possible oiling system problem, why would you worry about a HOTcam kit? Plus, if you have visible damage to your bearing and journal surfaces upon inspection a new oil pump is going to do absolutely no good at all. You'll be pulling the motor for a rebuild.
FastZinTennessee is offline
rideordie
11-05-2019 04:52 PM
alex5366
02-17-2015 08:12 PM
Queens94z28
12-20-2014 09:11 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: Cam and Lifters..
