cam lift question?
Old Jun 5, 2006 | 09:22 PM
sam pace's Avatar
cam lift question?
What is the maximum lift a stock LT1 take without modications to the pistons? the cam i am looking at is this one
cca-07-466-8
Operating Range: 1800-5800 RPM
Duration Advertised: 268° Intake / 276° Exhaust
Duration @ .050'' Lift: 218° Intake / 224° Exhaust
Valve Lift w/1.6 Rockers: .570'' Intake / .565'' Exhaust
Lobe Separation Angle: 113°
Any good advice would help me out thanks.
Also,
I looked up this cam on the comp cams site and their specs say with 1.5 rockers. Jegs site says 1.6
Which one to believe?
If I go off comp cams site this cam would be .608 int. and .602 ex. w/1.6 rockers
This is why i am asking this question just in case if i have to get the pistons cut.
Old Jun 6, 2006 | 09:32 AM
Chopstix's Avatar
Re: cam lift question?
the lift figures are stated with 1.6 Rockers.
The XFI Grinds assume you are running 1.6RR and the 918 beehive spring
You will not have any P2V issues
Old Jun 6, 2006 | 09:40 AM
jsetzer's Avatar
I have seen .63x run with no problems on stock bottom end.
Old Jun 6, 2006 | 12:47 PM
firetird's Avatar
lift is really not the biggest factor in ptv clearances. fwiw, i have .644" lift with my cam. i did replace my pistons but they were actually a little taller than stock and they had the same size reliefs. Im also running a 0.026 head gasket and my heads were milled (2.0 valve's). there is more room than people think... best thing to do is check with some clay.
Old Jun 6, 2006 | 09:42 PM
sam pace's Avatar
thanks guys i appreciate the info.
LeftoverChinese
Jan 14, 2024 03:03 PM
rideordie
Nov 5, 2019 04:52 PM
kandied91z
Jan 23, 2015 11:14 AM
1775.Z28
Jan 11, 2015 10:51 AM
