Cam install w/o pulling motor?
Old Jan 23, 2003 | 04:41 PM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Is it possible? Any how to's?
Old Jan 23, 2003 | 04:44 PM
Rodrigues's Avatar
Yes, infact I remember reading this exact same question a few days ago... search!
Old Jan 23, 2003 | 04:45 PM
95_RipperZ's Avatar
Yes, you will need to take out the radiator.
http://www.streetillusionsracing.com...ll/install.htm
http://www.afrashteh.com/guide/install.htm
Old Jan 23, 2003 | 04:48 PM
Kevin Blown 95 TA's Avatar
Sure, You need to pull the radiator and air conditioning needs to be disconnected. Then off with the water pump, fun pulling the hub, opti, lower the pan to get the timing cover off, timing gear off, intake manifold off, rockers off, pushrods out, lifters out, and Voila! out with the old cam, in with the new. Piece of cake! Need to upgrade valve springs. Also can be done with the heads in the car - lots of fun, I've done it twice.
Old Jan 23, 2003 | 04:50 PM
CamaroSS165's Avatar
It is possible. Just swapped cams for the 2 time.
A real help is the HAYNES manual, around 15-20 bucks.
Did a cam in a friends LS 1 in 4 hours.
Just take your time , the Haynes manual tells you
how to take it apart and put back.
And make sure you put it on TOP DEAD CENTER.
Either on #6 or #1. Make sure you put the cam in with
dow pin at the same location it came out. Or it will be
180 degrees off and could bend some valves if you try to start it.
Old Jan 23, 2003 | 04:55 PM
Buttercup's Avatar
If you plan on doing much work on the car, an official, GM, Helms shop manual is much better than the Haynes... but it does come at a price.
Cams may easily be changed in the car. If you're good, you don't even have to discharge the AC system.
Old Jan 23, 2003 | 05:03 PM
...and I bet you're good, ain'tcha?
Old Jan 23, 2003 | 05:06 PM
Buttercup's Avatar
Old Jan 23, 2003 | 05:18 PM
DJ:BOTA's Avatar
Great! I'm having a mechanic from work install, but didn't know if he could do it that way. TY.
LeftoverChinese
Jan 14, 2024 03:03 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
