cam install, leaks, high idle?
Old Apr 25, 2004 | 07:25 PM
blown383's Avatar
Okay I buttoned everything up on the Z28 after
installing -
New Opti
CSI water pump
Cloyes Double roller timming chain
Comp Cams Xtreme 236/242 on a 110lsa cam
Comp Cams pro Magnum 1.6 roller rockers
7/16 studs
EX-612 valve springs
New valve seals
Removed AIR and EGR
Unbalanced Engineering rag joint eliminator
Mail order tune.
So I fire up the car and it runs on the second try and
it idles like stock?!?! Mail order tune guy set the
idle at 950rpms but I was assuming with the 110ls it
should lope like a ****. *shrug* Anyone have a clue
as to why there is no lope? I even fired it up with
the stock PCM and it still idles high. Like 1,100+
After driving it for 20 mintues I pull into the drive
way to let it cool off so I can change the oil....well
after an hour or so I looked under the car for leaks
and its literally BLEEDING oil! When installing the
intake I didn't get the manifold in straight on the
first try so I bumped it a little to get it to settle
correctly. So Im assuming I have to reseal the
manifold again. ARRRGHHHH!!!!! Anyone have a part
number for that nasty grey GM manifold sealant?
Second thing is that I looked under the car and there
was coolant pissing all over the place!!! Apparently
it was the crappy squeeze clamps, they lose their
tension after a few years...so the pipe that has the
bleeder screw started to leak right at the pump and
pissed all over the new opti!!! =( Im going to use
a hose clamp and see if that was the only leak.
Also while installing the front timming cover I ripped
the oil pan seal but so far thats holding up since I
RTV the crap out of the corners.
Also are the pro magnums and comp "R" lifters suppose to be REALLY loud? They're a lot louder than the non-self aligning crane gold rockers I had before.
-B
Old Apr 25, 2004 | 07:40 PM
Cory1994z28's Avatar
sounds like the kind of stuff that happens to me when i am working on my car. As far as the mail order tune I would just call them.... and for every thing else, it looks like you have it under control... man those manifolds are a Bit*h, I just usualy load it with rtv and try to lower the back end in first.
Old Apr 25, 2004 | 08:26 PM
blown383's Avatar
The trick is trying to get the manifold to set properly underneath the oil pressure sensor...I think thats where I messed up.
-B
Old Apr 26, 2004 | 08:58 PM
blown383's Avatar
ttt
Old Apr 26, 2004 | 09:05 PM
gb95zconv's Avatar
-B
I put a couple of studs in to help guide the manifold down prefectly.....get um at the hardware store. Permatex gray rtv works well for me.
rideordie
Nov 5, 2019 04:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
